Best way to get a 100:1 arc voltage out of Powermax 85
Results 1 to 2 of 2
Thread: Best way to get a 100:1 arc voltage out of Powermax 85
    Member SSOKIE's Avatar
    May 2016
    Edmond, OK
    Default Best way to get a 100:1 arc voltage out of Powermax 85
    I'm surprised I can't find anywhere this has been mentioned before here, but I have searched up and down and can't find it, so...
    What's the simplest and/or best way to get a 100:1 signal from a Powermax 85 divider board?
    I realize a 100:1 signal is not the best to use but I'd still like to know.
    Nov 2013
    Default Re: Best way to get a 100:1 arc voltage out of Powermax 85
    Hypertherm machines typically have a 50:1 divider. If you really must have a 100:1 then just add a 2:1 divider at the output of the 50:1.
    Craig
