I'm having issues getting my proma 150 to work. I'm using an ESS with Mach 3. I followed the instructions listed in the setup page with no results. I'm unable to get any Z movement or get any of the lights to light up in the diagnostic page. I even tried disconnecting everything on the THC except the power supply wires (24V) and to see if I could get a voltage reading on the UP DOWN and ARC terminals. I placed the negative side of the meter to the COM terminal and positive side to the UP, DOWN and ARC terminals and put the THC in test mode. The THC shows the voltage changing in test mode and the UP and DOWN indicator lights on the THC are changing, but I'm getting no output voltage to the UP, DOWN, or ARC terminals. I'm not sure why....
