- Newbie- Advice Needed on DIY Project
Hi guys,
I am new to plasma cutting and need someone to review this conversion project I am working on to convert a laser system to plasma.
If you could just provide specific things you see as causing an issue and why. It would be much appreciated.
https://youtu.be/9iPv7MkFwjc
Re: Advice Needed on DIY Project
My main question is, what are you trying to achieve by doing this?
I assume you want to cut thicker material?
- You may not post replies
- You may not edit your posts
Forum Rules
