From the docs I read, it seems that the THC is designed for raw (undivided) arc voltage. Last time I looked, the 45XP did not have raw arc voltage output.
So that looks like an incompatibility. How do you read the arc voltage? Its possible the voltage is too low and it tries to correct this by raising the torch to increase the voltage and this extinguishes the arc.
