I have recently replaced the THC on my CNC plasma table. The machine Chinese and uses the Start Shapon SH-2012AH controller. I purchased the table without the plasma operational and the original SH-HC30 THC had a damaged plug and is now obsolete, hence the upgraded HC31.
So, I have wired in the new THC and it does not function correctly. It will cut, but will not automatically adjust its height and is not showing the 'auto' light illuminated. I don't think I am getting the manual/auto signal correct from the controller.
Hello KPB, I am considering buying this SH-HC31 model, I ask you:
1: does it work well on flame cut? THC? capacitive?
2: does it work well in plasma with thc voltage divider?
Bonjour
Moi aussi je viens d'acquerir une machine plasma avec Torch height control du type HC31 et le controlleur Start Shaphon. Quand j'essaye de couper qqe chose la torch touche la tole et la deplace, il me semble que la THC ne fonctionne pas ou n'est pas activée. Quelqu'un peut-il m'aider au moins pour activer la THC? Merci
Hello All, Happy new year.
Deos any one save how to turns out some settings on the Start Shaphon SH-2012 controller were not correct.for SH-HC30?
Thanks.
melon25
