I just finished my DIY CNC table and tried my first cuts.
My issue is that the M5 command gets active before the cut is fully ready. I have done a test by manually adding a delay time just before the M5 command of 1.5sec, and worked perfect!
What am I doing wrong? Is there a setting in Mach3 for this?
I am not using the Arc OK signal? (just because I am waiting to the THC to arrive).
