I am having an issue with my plasma cutting system that i am not sure where to start been thru everything . I am running a hypertherm powermax 65 thru a kyndill thc with a standard 5 axis breakout board , using plasmacam to write the g-code and sheetcam to run the g-code and Now to my issue i am getting premature torch turn off ... the start output from the breakout board is turning off mid cut and i have looked at the g-code and there is no m-05 turn off in the lines of code where it turns off at and on my kyndill when it does turn off i get a message of pierce timeout. anyone know anything about the kyndill thc or has anyone seen this issue?
