Looks like a fun project. If you can get the documentation for both the machine and the drives. If the documentation is not available, then rip everything out and start from scratch with modern hardware.
I'm guessing X, Y, Z (torch height control is most likely integrated into the controls)
I assume that is the relay output board, also maybe the input buffer, along with an integrated power supply. Common in older equipment.At user end is a DIGISAF 100 Computer (if you can call it that). Its a big black box with some round connectors on the back labelled:
- Cutting oxygen and power input
- Drive
- Plasma Function
- Serial I/O B
- Y Encoder Input
- X Encoder Input
- Serial I/O B (again)
It looks like some of these are going into the old looking bare circuit board below the amplifiers.
Now call me silly but I thought encoders talked to the amplifier in a closed loop system, not to the computer (which I guess is the controller?), so why there's an X and Y "Encoder input" is confusing. If someone can explain why I don't need this going forward that would be of great relief.
Looks like the loop is closed at the controller. Many older drives did not have the capability of closing the loop at the drive level.
Good plan.To the right of the DIGISAF 100 unit is a Nertajet HP which is the plasma cutter which is ancient and will hopefully be replaced with a modern cutter.
It might be a bit more complex than just plugging the drives into the new control. I'm also guessing those drives are analog command input so this will require a controller that has analog command outputs as well as encoder inputs. You also may need the programming software for the drives to be able to adjust them for the new controller, you'll have to look at the drive documentation to confirm this.The end goal (please stop me dead in my tracks if you think this is out of the realms of probability) is to rip out the DIGISAF 100 unit along with the old circuit board and the cutter. Then install a modern controller and cutter on the bridge (probably with a new THC). I'm really hoping that I can simply disconnect the amplifiers from the old circuit board and plug them straight into a modern controller.
