It is not as simple as it seems. I'll fix Burny. I can sell you a used 2.8 if you want.
or I should come to you to fix it.
If you can better detail the problem maybe I can help you.
Regards
Alfonso AQ TECNO
Hello to all . I bought a plasma cnc table with a burny 2.8 controller. After checking not always and always on the screen ... Input and stop .... I checked all the cables and I can't find the Problem please help me ... Thanks
- Need Help!- Modify Our CNC Plasma into High Definition Plasma and Brand New Electronics Motors
- Precision Plasma Patriot 4x8 CNC plasma table rotary axis pneu scriber powermax65
- NEED ADVICE I bought a 1988 MG industries 10' x 10; router/ Burny2.5 controller
- EZ Cut 8000 Series - 5'x10' CNC Plasma Table with Hypertherm Powermax 85 Plasma Cutte
- burny2.5 speed output problem
Regards
Alfonso AQ TECNO
