( Need help!) THC proma SD not respond from G-code command
Results 1 to 1 of 1
Thread: ( Need help!) THC proma SD not respond from G-code command
    Jun 2015
    Vietnam
    Default ( Need help!) THC proma SD not respond from G-code command
    Hi everyone,
    I have a problem with my THC proma SD. It was not responded the G-code command from the interface software. I've already checked the wiring and tried simulation testting from THC (test mode) all of them are correct and I don't know to solve this problem. Could someone please to advise?
    My setup:
    ( Need help!) THC proma SD not respond from G-code command-s-l1000-jpg( Need help!) THC proma SD not respond from G-code command-img_4752-jpg
    - 4 Axis Plasma tube cnc cutting machine
    - Planet cnc controller
    - THC proma SD
    - Hypertherm powermax 45xp
    Any advise will help.
    Thanks a lot.
    Attached Thumbnails Attached Thumbnails ( Need help!) THC proma SD not respond from G-code command-s-l1000-jpg   ( Need help!) THC proma SD not respond from G-code command-img_4752-jpg
