Solved.
The older Gecko 320 only used a +5v common for step/dir. The newer G320X can have a common +5v or Negative.
I am trying to hook up a Proma THC SD to my Gecko G320 servo drive on a new Plasma build.
The Proma wiring diagram attached looks simple enough but the G320 has a step, direction and common s/d +5v connection where the diagram shows a negative common.
What would be the proper way to hook this up.
Solved.
