Hey Dave,
Did you find it. Im just about to start building a machine for a guy and he has the razor cut 45. Not much is documented but from what i see it looks liek the machine torch for the razor cut 80 also works on the 45? IS this correct and did you get a pinout for the connector? Finally if you have been using it how does it compare.
