good afternoon, first of all I apologize for my bad English. I recently finished my cnc for plasma and I bought a thc robot3t with outputs up and down. I'm not familiar with thc and I do not know how it works. In theory it must work by measuring the tension of the arc and correcting based on the setpoint that it places. The problem is that I am not very clear about the function of the thc parameters. Would someone be so kind to help me adjust the thc? I have all the wiring placed, the correct configuration in mach3 but the thc does not regulate the height of the torch as it should. Thank you
It has to be paired with control software and hardware that can use the UP and DOWN to control the Z axis motor. MACH3 is one example. I think UCNC is another.
