Newbie Grounding HF plasma torch - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 27 of 27
Thread: Grounding HF plasma torch
  1. #25
    Jun 2011
    Default Re: Grounding HF plasma torch
    Pilot arc may still have HF start. I think it may be a bit easier to shield than non-pilot arc, as the return path for the pilot arc is in the torch head.
    What you want is blowback start, which I think is always pilot arc. Blowback doesn't use HF, so much easier to deal with as far as EMI goes.
  2. #26
    *Registered User* Bradnicent's Avatar
    Jul 2018
    What exactly is blowback and how does it work?
  3. #27
    May 2015
    Quote Originally Posted by Bradnicent View Post
    The arc is started by shorting the electrodes in the torch head then the air pressure "blows back" the contacts apart so the arc transfers to the material
    Rod Webster
    www.vehiclemods.net.au
