This is a common problem with the lower cost imported plasma cutters. There a few models and those from companies like hypertherm that play well with cnc machines and are recommended. Folks have tried just about anything you can think of to eliminate the interference (shielding, grounding etc) with limited or no success. Your mileage may vary, but a plasma cutter that has been tested and recommended for CNC use will save you lot of headaches. Yep, they cost more, but like everything else, you get what you pay for.
