That's not a Smooth Stepper.
Where did you get the board from? There's no manual?
According to a manual from a newer version of the board, try this:
I1 = Port 3 pin 1
I2 = Port 3 pin 2
I3 = Port 3 pin 3
I4 = Port 3 pin 4
Greetings
Can anyone please help, I’m attempting to wire a usb smooth stepper bsmce04-pp,for my plasma table, I got as for as getting the motors to run but no luck in setting up the limit switches as there are no PIN numbers on the board so I don’t knw what to tell mach3 on the input signal page ,does this board need to be powered as the db 25 bob? ,how do I knw where the common ground is for the limit switches? What port number do I choose?
Help will be highly appreciated.
I1 = Port 3 pin 1
I2 = Port 3 pin 2
I3 = Port 3 pin 3
I4 = Port 3 pin 4
UCCNC 2017 Screenset
Ok I got right.... According to another pdf I found in the manual ,the port number must b 3 and after doin that ,the red reset button bottom left came to life and I am able to change active low to neutralize the reset button ,but I’m unable to trigger is via a limit switch on the board itself, I also see in one of the PDFs the board is powered with 12/24v to the 24v and DCM pins.. is it really necessary to power it?
