Hi folks,
First, a little bit about my CNC/Plasma experience. I have already built 2 CNC, which are using the cheap chinese parallel port. I'm also using Mach3 as the operating software. So far they are both running fine .
I recently bought a used plasma, a Miller Spectrum 2050, which came with a hand torch and a machine torch. My intention is to build a CNC plasma table. I'm planning on using another one of those breakout board. Mechanically speaking, I'm very confident it will work.
The "grey zone" that I'm dealing with, is the THC . Feel free to correct my assumptions or statements.
My understanding is that this device will receive a "start" command from Mach3. The THC will then position the torch to the requested height, then send a "OK" signal to Mach3. Upon receiving the "OK" signal, Mach3 will the fire the torch, wait a bit of time then start moving. Once the cut segment is done, the trigger signal is removed. The CNC will then start moving to the new cutting position (X & Y)
Am I right so far ???
I want to build my own THC. I have a bit of experience in electronic design so I should (no braggin' here) be able to come up with something. Here are the basis of my design:
- The THC would be the one controlling the Z axis.
- Device would have a LCD display, where target height could be set.
- I'm thinking of a height adjustment between 2 to 8mm.
- A 5 VDC signal (from Mach3) would initiate the positioning sequence.
- A dry contact would close when torch height in within range.
- When no trigger signal is received, the height would go to 15mm (safe position).
- Height would (slightly) be adjusted while cutting.
- My "custom THC" would not interfere directly with the triggering of the Plasma. Mach3 would take care of that thru the switch on the machine torch.
Any thoughts of my "project" ?
Anything that I did not understand properly ?
Any suggestion ?
Now, if I have "passed" the test of "examination by my peers", anyone has an idea where I would need to connect it on the breakout board ? I have included a picture of the board that I using.
TIA
Jasmin
