Hey.
I have this problem with cnc plasma and wondering if anyone could give some help?
When i turn on the machine it immediately starts to jog away from the home switches really slow.
I cant home the machine because where i should go to home the machine is grey should be black so i cant select that.
I can jog against the slow machine movement but it gives servo error almost immediately.
If i push home switches with hands nothing happens.
Where could the problem be? Machine worked normally last time before shutting it down.
