i've noticed something with my plasma table, when cutting something with a "lower" speed the torch and torch mount vibrate. this is only noticeable when it's moving in both (x and y) directions. if i bump the speed up it gets way less worse. with a speed of 3000mm/min it vibrates alot (small fast vibrations) when i go up to 5500mm/min it's noticeable less
this may sound weird but i'm not sure if it has servo or stepper motor, if needed i could take picture of the motor setup.
is this something in the motor tuning or is it in the machine build up (not rigid enough)? or does anyone have a idea where the problem lies and could be solved
