have you added any thing new wire exct it could be interference in the arch pro manual there is a test to make the proma simulate the torch voltage wile not using the torch try that to make sure things work
some times interference does that. have you grounded the table with a ground rod are you using raw voltage if torch consumables go bad they cause eradic torch voltage that would cause the proma voltage to go up and down
