Messer gantry retrofit with HPR 130XD power source
We are a small business that is looking at upgrading our system below to improve cut quality and to do some outside cutting: Pictures attached of current system.
Most of our cut work is from 16Ga to 1.00" mild steel. 16Ga to 1/4" stainless.
Advise regarding:
1. Power source - HPR 130 VS HPR 130XD ?
2. Controller - (Burny 10 / Phantom II ) or other ? 3. THC - Commander VS Arcglide or other ? 4. Gas / air control ?
5. Chiller ( can I use my current chiller ?)
6. Can we use the current drive motors ?
7. Budget for this type upgrade ?
• Maximum cutting width 120"’ • Maximum cutting length 240"
Equipped With • BURNY 5 CNC Control • Hypertherm HT 400, (400 amp) plasma power source • Hypertherm chiller • Servo voltage torch height control • Rack and pinion drives (2 motors in X-direction and 1 x Y direction) • Burny Servo-pak model MT2630 drive motors • Power track hose and cable carrier system
• Hypertherm Pro-Nest layout software (2014) Laptop version with USB key.
