You can't use the parallel port with a 64 bit OS.
Yes, the ESS will work fine in Windows 10, as will the UC100.
I'd recommend the UC400ETH or UC300ETH over the UC100, though.
Hello I have a automation tek 4 axis cnc kit with the c10breakout board with mach3 connected via parallel port I get no action . I have Windows 10 64bit have installed drivers for the parallel port card but no communication to mach 3 . Hooked up to my neighbors ess with Windows 7 64 bit and we got movement just wanted to double check if Windows 10 and the warp9 ess kit will work if anybody knows ? Also I'm kinda skeptical on the uc100
Sent from my SAMSUNG-SM-G920A using Tapatalk
UCCNC 2017 Screenset
ESS board is good with window 10,
https://www.automationtechnologiesin...rd-for-mach-3/
