Contact the card manufacturer and ask if there plugin supports slaved homing.
Card MKX-IV. If the axis A configured slave from the Yaxes, when pressed “Ref all Home” Mach3 does not respond to the switch Ahome only switch the main axis. Don't work A axis home.
Mach3Mill.xml: https://yadi.sk/d/48R5yb4YtrH2n
UCCNC 2017 Screenset
Make sure that "Home Slave with Master" in General Config is NOT checked.
Sounds like the plugin does not support slaved homing.
Hello
I have the same card mkx-IV driver v2.39.9 and mach3.
Have you been able to solve your problem?
I have a switch on each motor of my axis (Y & A).
Axis A is slave to the Y axis.
When I run a RefHome RefHome (2),
1- Y and A move together until touching switch Y.
2- Y and A stop
3- Nothing happens but I have to trigger switch A by hand.
4- Y and A go back.
If I resume the step by first releasing the switch A
1- Y and A move together until touching switch A.
2- Y and A do not stop
3- I trigger the Y switch by hand.
4- Y and A stop
5- Y and A go back.
An idea of ??why this behavior?
MyShop
