i'm looking for lantek expert v 27
Results 1 to 11 of 11
Thread: i'm looking for lantek expert v 27
    Mar 2009
    greece
    Default i'm looking for lantek expert v 27
    hello there.
    its possible to tell me here i can find lantek expert v27. do you know any site to download it free.
    thank you in advance
    ps
    sorry if my question is illigal.
    Aug 2010
    Unfortunately no. I have not used Lantek in a very long time. but I will do a search for you and see what I can find.
    Jonathan
    Aug 2010
    Well, it is not free. this website shows it for $150.00.
    Here is the link:
    Lantek V27 - Mold - free-download|Unlimited|license|serial|unlock|keygen|free|activation|patch
    Aug 2010
    It states that it is free...but that is a 30 day trial I believe. Then after that it is 150.
    I hope this helps.
    Jonathan
    Feb 2015
    Default Re: i'm looking for lantek expert v 27
    Yes, i have it ISO File ... Uploading in Process .. then will share URL Link
    Feb 2015
    Here's the Download Link :
    Lantek v.27
    https://drive.google.com/drive/folde...nM?usp=sharing
  7. #7
    Oct 2016
    Bulgaria
    Quote Originally Posted by o_secret_k View Post
    Lantek v.27
    Hello, ty for the link. Is the version of Lantek Expert cracked because it require cd-key ?
  8. #8
    Feb 2015
    Quote Originally Posted by Lansvans View Post
    Check inside the ISO there is a Magnitude folder, there is a text file ... you will find the cd-key
    it's Mandatory to install LANTEK v27 on Win x32 bit Not x64 .. So the Emulator be able run
    any Questions iam ready to help
  9. #9
    dimitristef's Avatar
    Mar 2019
    Dear all,
    I have install it from ISO file and all goes well until the registration key, i put the key as decribed on txt file and i follow the steps correctly. when im trying to install the Emulator Utility on this step does nothing.
    Can you give me a little help on this step ?
    Thak you very much in advance !
  10. #10
    Mar 2019
    Dear all,
  11. #11
    Member Al3x89's Avatar
    Mar 2019
    Hello guys i am trying to install this but i get problems with SQL Server and stuff. Also don't find the Emulator in any folder?? Could i also get help? I need to learn the program realy well. Thanks!
  12. #12
    Mar 2019
    Hello,
    should that be Windows XP 32? Because on Win7 32bit after running emulator utility as admin, it opens but after pressing install emulator nothing happen. Any thoughts?
    Thanks in advance. Best regrads,
