Installed the x axis belts. Decided to go with Millman and use a bolt adjuster instead of the spring (although I may try it later just to see if it will work). Discovered a screwup when I installed the belts. I forgot to account for the loop around the idlers and drive pully when I ordered the belts so I ended up 5 inches short. Not a big problem since I won't be cutting anything that long.
Next on the list is the electronics enclosure and then we'll get this thing to move (at least a little).
Pics attached.
Willy
