Need Help! Z-axis not moving
Results 1 to 3 of 3
Thread: Z-axis not moving
    Member Andrewkbt's Avatar
    Jan 2021
    Default Z-axis not moving
    Hello members,
    I need your help. My Z-axis is not moving. What could be the problem?
    I really need assistance because I have alot of projects on hold because of this problem.
    Thank you very much
    Member awerby's Avatar
    Apr 2004
    Default Re: Z-axis not moving
    It might not be hooked up right, you could have bad pin assignments, a bad wire, a fault in your breakout board, a blown fuse, a computer issue, or a mechanical problem, among other things. Did it ever work, or is this the first time you've tried to use it?
    Community Moderator wendtmk's Avatar
    Dec 2005
    Controller? Steppers or servos? Drives? Nowhere near enough information to troubleshoot.
Z-axis not moving
Z-axis not moving
