Yes, you are right, the GSK980 is similar to Fanuc.
The GSK928 is much simpler.
GSK928 and GSK980 are built by different platforms, so their operations are different too.
GSK980 has PLC edit function while the GSK928 has not.
For GSK928TD-L first power on and initialized, if the program zero position is not set, then the default program zero point will be set as below automatically.
X=150 Z=200
If the CNC lathe has not set machine zero point (means no deceleration signal, no zero ponint signal)
We can use below to set up machine coordination.
INPUT U new coordinate value, ENTER, to set current X axis position as new coordinate value
INPUT W new coordinate value, ENTER, to set current Z axis position as new coordinate value
