hello,
i am using mach3 right now because i need the tangential control. it works but has a few bucks.
i saw mycnc can do tangential control but i find very little user reviews about this software.
has anybody used it and can tell his experience?
thanks,
michael
Yes I have been using myCNC software and boards for about 5 years now. all I can say is the faster you get away from Mach the better. The software that myCNC has is far superior to that of any mach stuff the smoothness of the steppers and the stability of the software is great. There is a but of messing around in the beginning , once you have got the system set up you are working with so much better equipment. The good thing is that it is cross platform and you can even run the software on a small SBC so you don't have to have this big clunky pc on your desk. If you buy the kits with the SBC and the touch screens you can put together a real kick ass system. The forum is also really great the help is relatively fast and always sorts out the problem. I truly recommend this software and hardware. check out the machine I built for a customer
hope this helps both you and the guys from myCNC
