I have an Anilam 1100M controller and am trying to figure out how to set part 0. I switch back and forth between incr. and abs. and nothing happens. I might be reading the programming manual incorrectly, but in the Anilam manual, I should be able to have a part 0 setting and then manually move the machine to different coord.s and then perform an automatic routine, ending up at 0,0 and then push Abs. and it would guide me back to part 0. Obviously I don't understand, so could anyone explain this to me. I want to be able, if my position becomes obscure, to be able to come back to a known 0,0-part 0. Please help. Is this something with the Anilam controller that has to be set up in configuration?
