now
ncstudio run and next is calibration..
you will seeing tabs somewhere left as,,,, Trace Log Manager Parameter I/O state
first click I/o state
simplified, if you seeing gren colored title and marked differently as "N" then right click on the title like X axis together with shift-ctrl-alt keys pressed and hold...
a little menu will coming up and you set state reverse
program will notify you after restart ncstudio state will be valid
after all title , calibration, xaxis,yaxis,zaxis, spindle 1-2-3 set to right state you restart ncstudio
next step to setting steps properly
I show here only for ballscrews... because for gears too many different and those machines likely coming with dsp handheld control.
there are two settings known
very generally, for nema 34 motors 10 mm leadscrews
for nema 23 motors 5 mm leadscrews
so you need to set for 5 mm lead 0.003125 value
or for 10 mm lead 0.00625 value
(if you have gears, rack n pinion, the they are different settings)
in same place you can set yet,
start-end mechanical cordinatas.. its your workenvelope or max movement on router on all axis.. set proper values
start up federate... this is when machine axis from steady state will start..
you can set it to zero... that will work for everything..
for ""3dcuts"" I meaning reliefs where you have million small segments unorganized, then you can set startup federate for a small value likely 40-50 mm
be careful set this to higher value because that's mean motor has no time to accelerating and it will lead lost steps..
set Z axis max speed it is experimental and you find the proper value..
mine is set to 3000 mm per min
linear acceleration... this is likely when vector start and router need to run up, or ramp speed up..
150-200 a good value
later you can make experiments and set higher or lower
connection acceleration... this when machine already in moment and got to a point between vectors.. this value you can set higher, 500 and up
with experiment you can find the proper setting..
spindle ... most spindle up to 24K some of 18K max rpm... set proper value
for delay to waiting for spindle run up or slow down you can use 5000 millisecond value
after these close this menu tab and go to machining tab
