Anilam offline 3000m and Win7 64b
Results 1 to 6 of 6
Thread: Anilam offline 3000m and Win7 64b
    Mar 2008
    Default Anilam offline 3000m and Win7 64b
    I've converted to WIn7 64bit and trying to get my Anilam offline SW to run again. First I got the 16bit not supported error, so I loaded up the WinXP mode and that seems to work, but now when I run the Anilam offline it says it can't initialize my graphics card to full screen. Setting The WinXP virtual OS to full screen first does not help.
    Anyone have any recipes that allow Anilam 3000m offline to run in Win 7?
    Thanks.
    Jun 2004
    Default Methods
    I use 2 different programs both works in different ways.
    The first one is free and though a little hecky I think it is best. Do search for DosBox.
    The second one is VMware it was also free. Once you install it you have to install XP in it's virtual machine that it creates. So you have two operating systems using one computer. Hopefully not at the same time. :-) It does work OK but I'm just not as comfortable with it.
    Mar 2008
    Default Re: Anilam offline 3000m and Win7 64b
    Install a program called DosBox. You can download it here... DOSBox, an x86 emulator with DOS
    Then you need to configure it to make it easy to run the Anilam offline program.
    Go to "Start" button and then "All Programs"
    Find "DOSBox-0.xx" program folder and click it to open
    Then click on the "Options" folder
    Then click on "DOSBox 0.xx Options"
    Note: if it doesn't open and asks you to select a program, pick "Notepad"
    When that opens, scroll to the bottom and you'll see [Autoexec] section
    Add the lines below
    mount c c:\p3m
    c:
    runcnc.bat
    Save the file
    Now run the icon on your desktop named "DOSBox 0.xx"
    Mar 2008
    Quote Originally Posted by springer- View Post
    Add the lines below
    mount c c:\p3m
    c:
    runcnc.bat
    Save the file
    That worked with a few modifications.
    There is no folder in my start/All Programs path for DOSbox. Just a single executable not in a folder.
    The file: C:\Users\xxx\AppData\Local\DOSBox\dosbox-0.74.conf is the file I had to add the Autoexec lines to.
    When it comes up Anilam complains about unknown drive type (CDS), cannot perform disk check on C: Press f10 to continue.
    After pressing f10 it seems to be happy.
    Thanks for this!
    Activation process slasher102's Avatar
    Jun 2018
    i am trying to do the same thing but after the CDS it says error at the top and then cannot find your controller board. i just wanted it offline any idea's
    Mar 2008
    Quote Originally Posted by slasher102 View Post
    Offline should not be looking for a controller board. Are you sure you are running the offline version?
