Hi. We have two Acer mills with the Anilam 3000m control. I have Windows XP and WOULD APPRECIATE IT VERY MUCH IF SOMEONE COULD HELP ME FIND A COPY OF THE SOFTWARE for TRAINING/LEARING THE SOFTWARE AT MY COMPUTER AWAY FROM THE MACHINE I have been doing a lot of studying on the operation and programming of these mills, but just don't have any down time to write programs or get more familiar with the software. I tried to install "ANILAM 3000M-3x CNC SOFTWARE Version PC3.81A/ DSP2.50x" from a floppy to my desktop pc. I thought this was the correct disk, but I get an error that "DSP chip not ready" , or some error related to DSP. I am not sure but I think this disk is for the machine itself. Thank you.
if you contact analam directly for the software.[Analam 3000m offline]
the software you are trying to install is for the machine itself in the folder there should be a disk marked offline .. that is for your PC.
in all honesty i found the offline software to be confusing, because the program had to be finished for the screen to do anything
where as direct programing in the machine if you not sure you can input line by line and watch the result. I.R.L.
the program is relatively easy to use in comparison to some other opperating systems
Captain Crunch, If you will email me I can probably help you out. I like the offline as I can sit and run my programs and find goof ups alot easier than standing at the machine inputing everything . tlmkr38@gmail.com
Has anyone come across the 3000M offline software? Guessing my floppy disc I have is bad. I cant get all the files to read to install. Any help would be appreciated
About half way down the page you will find the download link and the instructions to install it.
Depending on your operating system (anything after Windows XP) you will likely have to install a program called DosBox. You can download it here... DOSBox, an x86 emulator with DOS
Install it. Then you need to configure it to make it easy to run the Anilam offline program.
Go to "Start" button and then "All Programs"
Find "DOSBox-0.xx" program folder and click it to open
Then click on the "Options" folder
Then click on "DOSBox 0.xx Options"
Note: if it doesn't open and asks you to select a program, pick "Notepad"
When that opens, scroll to the bottom and you'll see [Autoexec] section
Add the lines below
mount c c:\p3m
c:
runcnc.bat
Save the file
Now run the icon on your desktop named "DOSBox 0.xx"
Download still works on the wayback machine. I just downloaded and installed the anilam software and dosbox.
I haven't figured out how to make the autoexec.bat file work correctly, but can type in
mount c c:\p3m
c:
runcnc.bat
and it opens the software. The function keys are accessed with the keyboard function keys. Enter = select. Escape is back. In the DXF utility, to leave the window (I'm on windows 10) press the windows key. I'll work with it some more and see if I can get a DXF file into my mill, I have a YCM 1 1/2 mill with anilam 3000M CNC in my garage, and I just got the VFD completely installed yesterday.
Reason: Incomplete post
aggiford,
I would like to install the offline software as well. You don’t mention which type of computer you have? I use a mac and wondered if it would work with the dosbox? I am not so great with computers but fumble my way through usually.
I have an HHRoberts mill with the 3000m control and use it for a variety of work.
I know this is an old thread but hope you will get a notice and then respond.
I use a IBM so I'm not sure if it will work on a Mac or not with dosbox however I think it probably would as Dos is an IBM format I believe Luckily we still have a computer old enough to run it so I don't have to use DosBox but a guy that worked here had it running on his with it at one time.
