Travis, I know this post is very old but can could you post a pictures oh how you rewired everything please? I have the same issue and trying to figure out how to rewire everything, also the huge 140 ohm cilinder thing fell apart ( what should i order to replace it?
Thank you Travis,
Did you remember if you replaced the cilinder resistance? did you replace the wires too? I called the company to see if they had an old parts and wiring diagram and are doing some research on it but doubt they will find anything. BTW I discovered that it's not a grinder/buffer... as crazy as it sounds it is a dental lathe lol!!!
Sorry but I don’t.
Sent from my iPad using Tapatalk
