The simplest way is to use a 24vac transformer, use a bridge rectifier and a 200uf capacitor on the output. This will give you ~+30vdc to the motor, which is close to its limit.
Hi, guys !
This is my first post here and I am glad to join your community.
I would like to get some advice on how to force my 775 motor on T8 CNC machine to rotate faster.
I have SVEN PU-600AN (see photo) which gives enough power (480W /40A) for spindel and steppers, but limited to only 12V. To increase rotation speed I would like to step-up the voltage without losing the power. I see many DC/DC 12V/24V converters on the market, but they are very expensive (compared to my T8), so I am looking for optimal solution.
Any suggestions, please !
Thanks in advance.
775 motor specifications:
https://somanytech.com/what-is-775-motor/
T8 specifications:
https://hobbyking.com/en_us/t8-diy-3...-and-grbl.html
Thank you for reply, I have seen something similar and ready to use, but I am afraid that it has no enough power:
https://www.aliexpress.com/item/1005004285958078.html
Beeng software developer, I am not familiar with electronics, so some concrete schematics can help me a lot.
If you know how to put one together, this is the circuit.
Thank you very much, soldering is not a problem )
"You are what you do, not what you say you'll do."
Carl Gustav Jung
