Originally Posted by
viroy
the red wire on the VFD is just a wire... not connected to the BOB, but i wasnt sure if i needed it so i hooked one up... simple as that... so its just hanging there
The 24vde2c power supply is connected to the BOB on pins 24v and DCM... it is the only thing running off the 24vdc power supply, I had to buy it just for the BOB and is the only thing its used for
I changed the spindle output from 3-1-3-1 to 1-1-0-0 as you asked, no change at all... no voltage whatsoever, its a flat 0.0vdc on any setting (M3 S24000, M3 S100 and so on)
but if the spindle is set to port 0 on the motor output tab, and the clockwise M3 is set to port 1 on the spindle tab... is this not wrong?
