You mean one of these?
https://www.rcscomponents.kiev.ua/da...-datasheet.pdf
Any breakout board which can deliver a 5v pulse & direction signal.
So I assume you're on a budget?. If you can get a pc with parallel port and 32 bit win7 or xp then:
Most are or better setup to be wired common anode as per page4 fig2 in the driver manual above.
Such as:
https://www.aliexpress.com/i/33042193580.html
https://warp9td.com/images/BOB_Vendo...line/ST-V2.pdf
I used one of these for a few years and was great.
There are many boards that can be wired either way so be careful with your wiring and double check everything as you go.
Such as:
https://www.automationtechnologiesin...breakout-board
For controlling via usb if you have no parallel port I would NOT touch the NVEM based units such as:
https://www.amazon.co.uk/Motion-Cont.../dp/B07L4QVQCB
These are the most common boards used in basic chinese hobby machines when using usb:
https://www.aliexpress.com/item/1005...912f169576e347
If wanting to use a laptop (or aanything win10 based) to run it then go with an ethernet controller such as the UC400eth (if using Mach or uccnc).
Attach the 5 axis board at top of list to it using an idc26 to db25 cable (or both top baords using both ports for more IO)
For an all in one ethernet based system I'd recommend an AXBB-E.
