Need Help! power supply
Results 1 to 6 of 6
Thread: power supply
    Sep 2010
    Slovenia
    Question power supply
    Years ago I got a cheap SMC1800-50V-33A power supply. The power supply has an output of 50.5V. My CL57T controllers (3 pieces) are designed for 24-48v.
    Will 2.5v more be too much for my controllers?
    Jan 2018
    United Kingdom
    Default Re: power supply
    Yes.
    Does your supply have a little adjusting screw to lower it a little?.
    If not:
    Either change to CL86 drivers
    Or
    Get a new supply such as:
    https://www.aliexpress.com/item/1005...50529870%22%7D
    https://www.aliexpress.com/item/4000...25617994%22%7D
    There are loads of different options on the site. I have 80v, 60v, & 36v supplies from there.
    Mind you. Do you really need as much as 33A for 3 drivers?.
    You'd still be extremely comfortable with 48v 1000w.
    In which case I would find one of the adjustable voltage units in your input range and run it at 45v.:
    https://www.aliexpress.com/item/4000...c00uog8Pk&mp=1
    Sep 2010
    Slovenia
    I found a trimmer on the front panel and will try to lower the tension. I got this power supply years ago for little money. Back then, the prices of power supplies with such power were expensive. I also need to train my cnc because I have some work to do and the wait from China takes me too long.
    Sep 2010
    Slovenia
    Unfortunately, the trimmer drops the voltage only to 49.96V.
    Member cncmakers001's Avatar
    Jul 2011
    China
    Quote Originally Posted by kunte View Post
    Better find a new suitable power supply.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Sep 2010
    Slovenia
    I have already ordered via ebay 48v 10.4A for € 64.68. I already have the same. I will connect 2 CL57T controllers to each, and another CL57T and Leadshine DM556 to the other. For XYZ axis I have Nema 24 stepper motors 24HS40-5004D-E1000 4Nm 5A, for 4 axis so I have Nema 23 , 24H290-42-4 3Nm 4.2A
power supply
power supply
