Hello;
How do you plan to drive the output stage?
Sign-magnitude?, Locked Anti-phase?
If you employ the former you might have to add a charge pump to help recharge the bootstrap capacitors when the motor is running in one direction for a long time.
If you employ the latter, then you don't need those high capacity caps on the bootstrap circuit (depending on the PWM frequency).
Regards,
Kreutz.
