How important are fuses and where should I put them?
Results 1 to 6 of 6
Thread: How important are fuses and where should I put them?
    Jun 2017
    Default How important are fuses and where should I put them?
    I am building my contoll cabinet now and am thinking about fuses. Do I want them and where should I put them?
    I have an acorn board running 3 stepper online CL57Y drivers that supposedly draw 5 amps each.
    Member mactec54's Avatar
    Jan 2005
    Default Re: How important are fuses and where should I put them?
    Quote Originally Posted by setlab View Post
    Unless they are light loads you want to use circuit breakers in your cabinet all main supplies Ac or Dc should have a Breaker or Fuse rated for load plus 150%
    Mactec54
    Dec 2003
    A big help is a copy of NFPA79 "Electrical Standards for Industrial Machinery"
    You can find a copy in PDF out there on the web, may be a little dated, but most still applies.
    Jun 2017
    So say I have your standard mean well DC power supply, I would want a breaker or a fuse between its output and my drivers that can do 150% of the output?
    My driver power supply is a 48v 21a DC supply, is that considered bigger than a light load?
    I'll look around for the regulation book.
    Dec 2013
    Just to clarify, since your drives are rated at 5 amp input, you would want about a 7 amp slow-blow fuse between the power supply and each drive.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2003
    Just as an aside, I much prefer linear power supplies due to their extra ruggedness.
    You do not need a regulated supply for steppers-servo's
    If, or when they fail, SMPS are much harder to fix.
    I would rather pay a little more, out of the gate for reliability.
    Just my 2c
    Al
    AnshKUM's Avatar
    Oct 2019
    ANAND
    Yes, you have to put the fuse in the circuit, Fuse should be fast blown before the acorn board supply.
    rest you can go with MCBs, But fuse is more responsive.
