Wiring Info:
PC using a parallel card going through the parallel cable to the C10.
C10 powered by USB brick, 5V 1A. 5V goes to power and enable, GND goes to GND
C10 jumper settings:
Pin 2-9 set as output
Pin 2-9 set as pull down
COM set to 5V
Pin 2 going to PUL- on the KL-5056
COM going to PUL+, which is also attached to DIR+
Pin 3 going to DIR-.
So with the wiring setup on this drive, Pins 2 and 3 on the C10 are controlling everything. Is there anything wrong with this setup?
