Newbie Want to replace parallel port BOB with USB one.
Results 1 to 14 of 14
Thread: Want to replace parallel port BOB with USB one.
    Oct 2006
    England
    Default Want to replace parallel port BOB with USB one.
    Hello everyone,
    I started building a DIY cnc many years ago and unfortunately life got in the way.
    Control wise I got as far as assembling the stepper motor driver boards and the BOB and had the stepper motors wired up and working on the bench.
    The drivers were from a kit by Lucas that I found on this forum.
    (Old thread here https://www.cnczone.com/forums/open-...395-posts.html)
    and these were the drivers I built THB6064 traditional description
    I am in a position to restart the build but want to use a usb BOB instead of the parallel port one I have BOB4 description
    I want to still use the driver boards I built.
    Can anyone suggest a usb bob that might suit my needs? Or is there some sort of usb to parallel converter that works well?
    Thanks for any advice.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Want to replace parallel port BOB with USB one.
    What software will you be using?
    UCCNC 2017 Screenset
    Oct 2006
    England
    Hi Gerry,
    Thanks for replying.
    I am open to suggestions.
    When I had it 'working' before I was using Mach 3 and that seemed fine for what I wanted to achieve. Is that still an option? I mean I think I have the XP system with Mach 3 on it still in the workshop (garage) somewhere but I don't know if it still works. Also I wouldn't like to hang it on the web but maybe I shouldn't do that with the controlling pc anyway?
    Mach 4 hobby doesn't seem too expensive.
    Or maybe Linux CNC? I have some experiencing with Linux and once set up it is ok.
    Could this be a solution? https://www.cnc4you.co.uk/UC100-USB-Motion-Controller
    May 2004
    You might want to check out grblHAL. No SW license fees. It's a 32 bit version of GRBL and runs on quite a few different processors. https://github.com/terjeio/grblHAL I have a USB (and Ethernet if desired) breakout board for the Teensy 4.1 (600 MHZ ARM M7) that a number of people are using. I have a few BoBs with all the SMD components on it in my tindie store. https://github.com/phil-barrett/grbl...ster/README.md
    Here's an earlier version of my system case. I'll be posting a full build description of this for my extruded AL router in the future.
    Want to replace parallel port BOB with USB one.-img_20200813_194025-jpg
    Oct 2006
    England
    Thanks. That is interesting. I am playing with grbl currently.
    I have had a quick look at the drivers I made and it looks like they each want 5V on the ribbon connector. Could I break that out and power it directly from the grblHAL +5V output? Would it being enough amps (ma?) for my 4 boards.
    Want to replace parallel port BOB with USB one.-6564_trad_connections-jpg
    Here is my case.
    Want to replace parallel port BOB with USB one.-2012-12-26-19-10-21-jpg
    Attached Thumbnails Attached Thumbnails Want to replace parallel port BOB with USB one.-6564_trad_connections-jpg   Want to replace parallel port BOB with USB one.-2012-12-26-19-10-21-jpg
    May 2004
    Yes, I think it would be fine. Maybe even powered by the USB +5V. Worst case, you would need to supply separate +5V (the BoB is set up to allow that). You should go through the exercise of adding up all the current draws for your drivers. If it adds up to more than 150 mA for your driver boards, then a separate +5V supply would be needed.
    I do have one concern about your optoisolators, the data sheet seems to want fairly high current for the LEDs. While I think it would be ok, it is probably pushing the specs of the output drivers on the breakout board. The Avago data sheet doesn't seem to give the Vf value of the LED so I don't know what their forward current would be with 270 ohm resistors.
  7. #7
    Mar 2003
    Shelby Township
    If you want to keep using Mach3, get a UC100 from CNC Drive. That's all you need.
  8. #8
    Member coherent's Avatar
    Apr 2003
    Arizona, USA
    I understand wanting to get away from the parallel port, but USB also has it's own issues. I would recommend going with Ethernet since you're upgrading and having to buy new components anyway.
  9. #9
    May 2015
    or keep your BOB and go with Linuxcnc
    Rod Webster
    www.vmn.com.au
  10. #10
    Oct 2006
    England
    Thanks for the responses everyone.
  11. #11
    Hi Gerry,
    I have a Mach3 controller. The old type which has DB25 parallel port and a USB to power the board. Can I use a DB25 to USB adapter/convertor and run it through USB of my laptop?
    The other alternative is to buy Mach3 which is USB driven but its 4 times costly here.
  12. #12
    Oct 2006
    England
    Hi Tony,
    Your controller sounds like mine. This is the easiest way of going from parallel to USB CNCdrive - motion controls
    D
  13. #13
    Mar 2003
    Shelby Township
    Quote Originally Posted by Tony_Stark View Post
    Hi Gerry,
    No, USB>>Parallel converters will not work with Mach3.
    You can use either a UC100, or even better, a UC400ETH.
  14. #14
    Thank you for reply.
    It is not available in my country plus its costly . I shall buy the new mach3 usb 4 axis controller instead then.(chinese one) fits the bill and works.
