Newbie Limit Switch in DSP0501 - Can I use a simple NO switch as limit switch
Results 1 to 3 of 3
Thread: Limit Switch in DSP0501 - Can I use a simple NO switch as limit switch
    Member silver_fx's Avatar
    Aug 2020
    Default Limit Switch in DSP0501 - Can I use a simple NO switch as limit switch
    I am converting an old Berco Surface grinder / milling machine to CNC using DSP 0501 and Gecko 201. I need to and I like to have limit switches on the 2 axis but I see the wiring diagram in the manual shows NPN limit switches.
    Is it possible to use NO or NC mechanical switches for this?
    I have attached the relevant page of the manual
    TIA
    Tom
    Attached Thumbnails Attached Thumbnails Limit Switch in DSP0501 - Can I use a simple NO switch as limit switch-dsp0501_wiring-jpg
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: Limit Switch in DSP0501 - Can I use a simple NO switch as limit switch
    Quote Originally Posted by silver_fx View Post
    Yes, absolutely. NPN NO switch can be directly replaced with a mechanical NO switch. Connect the switch to the BLUE and the BLACK wire.
    P. S. Why not use proper inductive switches? They are fun to work with, they have built-in indicator lights for troubleshooting, and they cost peanuts nowadays.
    Aug 2020
    Thanks vm. Well I will be but I have none yet, just order them but I thought in the mean time I can try the mechanical ones which I have e few.
