Just add one MC3487N QUADRUPLE DIFFERENTIAL LINE DRIVER or similar.
I'm doing a centroid retrofit with allinone DC controller and happen to have this mpg handwheel from a machine that got scrapped. I'd like to use it for a pendant for my retrofit. Is there a way to use this unit? Doesn't have a few of the connections the controller requires- only has the 4 wires you can see on the back- +,-,A, and B....
- Centroid CPU10 encoder connections - Replacing Servo3IO with Acorn
- Encoder/servo selection for a Robotool centroid retrofit
- Centroid OAK board keyboard interface question
- Need some help with a Centroid M400 - CPU7P3 - Z axis encoder connection bad.
- Interface board Rodgers board/ Romaxx Encoder Interface.
See my stuff for sale at http://stores.ebay.com/Industrial-Tool-and-Machine-Works?refid=store
Make no mistake between my personality and my attitude.
My personality is who I am. My attitude depends on who you are.
Is there a ready made, cheap, screw terminal module that will get the job done?
Someone just sent me a link to one, cnc4pc model c72 should do the job I think. Thanks though!
Yes, the C72 module will work for this. It will convert the single-ended signals (A and B) to differential signals (A+/A- and B+/B-).
