Is there a way to test on the board itself whether the home switches are working. this is on a home built cnc router that I've had for years and just decided to put home switches on it. I just added the spindle to the relay to turn on and off and that works fine. On a side note this is running on cncpro from yeager automation. The attachment is the board I have. Thank!
Greg
thank you!!!
