Relay is controlled by pin 9. Drive enable is pin 1. And about the relay. It is not stuck closed because if control power is off and vfd on, spindle doesn't run. It runs only if I have vfd on and power on the control and hear the click sound of the relay. Which shows that relay is not stuck but somehow receives a signal when board powers on, even if the board is not connected to the parallel port.
