220V seems correct. The wire size required is a function of the amp draw, not voltage, so the wire size is fine, that motor draws almost no current. If the motor is not working, then it is most likely dead. You might pull the motor off of the oiler and see if the shaft is turning, it will be turning very slow (about 6 RPM) if the motor and gearbox are good.
