Need Help! driver fault?
Results 1 to 6 of 6
Thread: driver fault?
    Jan 2012
    Default driver fault?
    when using closed loop steppers the drive fault can that be wired along with the E-Stop?
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: driver fault?
    Not directly. E-Stop is typically a pair of NC contacts, and drive fault is typically an open collector output.
    You could wire all your drive fault outputs to a small auxiliary relay, and then wire that relay in series with the E-Stop.
    Jan 2012
    Quote Originally Posted by CitizenOfDreams View Post
    I don't understand could you draw it out? Relay what one to buy?
    Nov 2012
    Something like this. Pretty much any small relay SPDT relay will work, as long as it has the right coil voltage.
    driver fault?-relay-png
    Jan 2012
    Thanks I understand now. Pony tail all 3 drives to relay to the e-stop button to the bob
    Nov 2012
    Yep, that's it. Don't forget the diode to keep the drives safe from back EMF.
driver fault?
driver fault?
driver fault?
