Strange as it seems it does work in reverse as I have done it. Since the wires are usually rated for 600 volts, nothing bad should happen.... but if smokes comes out.
VA is VA same as Watts kind of anyway, it comes out about 4 amps when I calculated quickly, You might look for a larger transformer or figure out a buck/boost wiring arrangement but VA is still VA.
