Using Hall Effect sensors as limit/home switches
Results 1 to 7 of 7
Thread: Using Hall Effect sensors as limit/home switches
    Gold Member Mr.Chips's Avatar
    Sep 2003
    Default Using Hall Effect sensors as limit/home switches
    After reading a few posts about the advantages of using hall sensors I have ordered some for my CNC.
    Instead of the bare A3144 sensor I ordered it as a module, thinking it would save me some time and make for a better signal, but I’m not sure, so I need some advise.
    Here’s the module from Amazon.
    https://www.amazon.com/dp/B072VVRNB7..._0Ek0CbZTZWECE
    Looks like I just need to supply 5 VDC and ground to power it, and connect it to the appropriate pins on the control board.
    Could someone make me a simple drawing showing labeled connections? If it can show point to point connections for one axis I can figure it out for the rest.
    Last edited by Mr.Chips; 05-06-2019 at 05:55 PM. Reason: Hit the post button before i had all the information.
    Mar 2017
    Default Re: Using Hall Effect sensors as limit/home switches
    Did you forget to add the link?
    Mar 2017
    Also, that sensor requires a magnet. The sensor detects a magnetic field.
    Did you look at other sensors that detect ferrous metal?
    https://www.amazon.com/Jhe-LJ8A3-2-Z...-2-spons&psc=1
    Sep 2003
    hello can anyone help?
    Mar 2017
    From Amazon:
    Module Interface Description
    VCC: Positive power supply, 3.3 V to 5 V
    GND: Negative power supply
    DO: Digital signal output
    AO: Analong signal output
    All you need to do, is hook the VCC Pin to +5V DC, Connect GND to ground, and DO is the digital output that you would connect to your BOB on one of the digital inputs.
    No need for the AO pin as that is an analog signal. You don't need that.
    Also, then mount a magnet on the machine where you want the switch to trigger. I would expect that the Output of the module DO will go low (zero volts) when the magnet gets close to the sensor. When it is not close, it should be high (5 volts). Also, it looks like the module has 2 LED's on it so you can tell then the magnet has triggered the sensor.
    Sep 2003
    Quote Originally Posted by maxspongebob View Post
    From Amazon:
    Could this device be used as a Normally open as well as a normally closed device?
  7. #7
    Mar 2017
    There is not enough information in the Amazon description to say yes or no. However I suspect the answer is NO.
