Newbie Do I need a larger breaker in my house ? How do you keep track of power consumption?
Results 1 to 5 of 5
Thread: Do I need a larger breaker in my house ? How do you keep track of power consumption?
    Activation process umfan110's Avatar
    Jun 2018
    Question Do I need a larger breaker in my house ? How do you keep track of power consumption?
    Hows it going guys, so I am pretty new to the CNC world and I have been doing quite a bit a research on different stepper motors, drivers, control boards, ect. My only concern is that I dont know if my house can provide all that power without triggering a circuit breaker. Just as an example, I was looking at this kit (https://www.ebay.com/itm/USA-EU-FREE...2f53af53e37d49) and the power supplies are rated at 350W each and there are three of them not including the VFD. Thats around 1000 Watts, not including the VFD, and if my house has a 20A beaker with a 110V output then I have 2200 Watts right ? I have a fridge and some other components in the garage that are connected to that breaker. So I guess my main question is how do you guys keep track of how much power these machines are drawing, can I just add up the wattages of all the components ? should I get an electrician to put a larger breaker in my house? As you might of noticed by now that I am not the most knowledgeable when it comes to electricity.
    Mar 2003
    Shelby Township
    Default Re: Do I need a larger breaker in my house ? How do you keep track of power consumpti
    Not sure what kind of machine you are looking at, but there's a good chance that those motors would be a terrible choice. Bigger is NOT better when it comes to steppers.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Jun 2018
    Thanks for the feedback. Care to elaborate as to why bigger is not better when it comes to stepper motors.
    Dec 2003
    A breaker alone does not do, there is also cable sizing.
    I assume you have at least a 100amp panel?
    Most are 200amp now, you may have to run a separate circuit, If you do, run a 240v supply this also gives 120v and more options.
    Jan 2005
    Quote Originally Posted by umfan110 View Post
    Because those motors lose torque very fast. Look at the torque curve in the ad. When you hit 300 RPM you have already lost almost 1/2 of the torque rating .
    As an example for comparison, The Automation Technologies 640 oz-in stepper produces more torque at 700 rpm than the 1700 oz-in motor you have linked (200 oz-in vs 150 oz-in)
    So unless you application is for lower rpm, you may be better off with a smaller motor.
